Encryption Of The Email Outlook In The Year 2010
Encryption means the activity of converting the data or information into a specific code. What is meant by an encrypted email outlook 2010 and how can one achieve this?
Encryption of sending and receiving the messages needs both the source and receiver to have a specific digital ID. The encrypted email outlook 2010 has two methods. They are:
1. Encrypting an individual message:
• Choose the dialog box launcher in the more options group of the options tab of the message being composed.
• Select Security settings and check the encrypt message contents and attachments box.
• Specify the message and click on the send button.
2. Encryption of all outgoing messages:
• Select Trust center settings in the trust center of the options present in the file tab.
• Check the Encrypt contents for outgoing messages box present under the encrypted email in the email security tab.
• To modify the anything in additional choose the settings after selecting the content we need to modify.
Encryption in email is also possible but the person who will receive it should also have an email that supports encryption. When you encrypt an email message with Microsoft Office Outlook, the readable plain text message in the email is converted into a scrambled cipher text.
The person who will receive the message should use his private key and it should match with the public key used to encrypt the message. If the person doesn’t have the private key, he will see the message “This item cannot be displayed in the Reading Pane. Open the item to read its contents.”
If he tries to open it, a dialog will appear with the message “Sorry, we’re having trouble opening this item. This could be temporary, but if you see it again you might want to restart Outlook. Your Digital ID name cannot be found by the underlying security system.”
If you want to encrypt a message using Microsoft Office Outlook, start composing your message. When you are finished, in Office Outlook, click “File,” “Properties,” “Security Settings,” and then check “Encrypt message contents and attachments.” Enter the rest of the details for your email like the “To” and “Subject.” When you are ready to send, click “Send” to send the email.
Notifications
