Endless Capabilities of Wireless Speakers for Desktop and Android
Hello!
I am sorting all best speakers available in the market now. I want to know more about Kicker KPw Wireless Speaker System. What the features of this speaker? How many speakers included? How much if i'm going to purchase? Does it comes with dock where I can recharge it? How long does it take to complete battery charging? What are the ports available to connect it with desktop or Android? Is there any usb port that I can use for maintenance purposes?
Answered By 5 points N/A #175420
The Kicker KPw speaker is Bluetooth portable wireless speaker. The total 5 hours required for charging before first use of it. The USB cable connect the power supply to charging port which is micro USB charge port. It also supports to answer incoming phone calls and communicate with built in microphone. To use this feature you just want to press Bluetooth|Phone button to answer. It has two 44 mm full range drivers and two 52 mm passive radiators. It has response frequency 180 Hz-20 KHz. The battery is Lithium ion 3.7 V.
