Engineering Software for Calculating Bar Bending Formulas
I am a structural engineer, I need a software which can easily accomplish some calculations for bending a bar. Is it possible for me to get a software with engineering bending formula for bar functionality?
Answered By 0 points N/A #153324
Hello Chad raymond,
Hope that my message finds you well.
You can Try the Engineering Tool box its kind of online calculation tools
for Dynamic Systems , fracture mechanics and others, that may help you to accomplish your
job: there website-> http://engineerstoolbox.com/
Also you can try the Hydaulic Calculaterfor the Diameter & speed of sporckets its a tool
created by Baum Hydraulics Company
Hope this solution will help you and please let me know if you need anything else.
Kind regards,
