Enhanced Defraggler Portable 2.10 Software
The latest Defraggler Portable 2.10 is very functional in its way of working. But it’s kind of slow. Is there any way of speeding up this software?
The Defraggler is already a very light weight application in terms of system resource usage. However if you want a quick solution you can try the quick defrag mode available in it. Though its not a full fledge alternative for complete defragmentation but can become handy if you want to do something seldom. Moreover you can schedule it to run automatically anytime and it will continue to run and defrag your hard drive with your interference or presence. The defraggler has one he other possibility of having defragmentation quickly by selecting manually a file or folder i.e. any location you want to be defragmented.
That problem is probably due to the fact that you are using a portable version. Though a full version and a portable version work the same, they function differently internally. A portable version contains fewer files compared to a regular version. If you are using a portable version of Defraggler, try using the regular version.
It is quite bigger than the portable version but it will give you a much stable and optimal performance. Also, before using the program, make sure your computer meets the requirements. Defraggler supports Windows XP, Windows Vista, Windows 7, Windows 8.1, and Windows 10 both 32-bit and 64-bit. If you have Microsoft Windows 8, better upgrade to Microsoft Windows 8.1.
To get the latest version, go to Piriform Defraggler.
