Enlightenment Desktop on Ubuntu Linux
Guys, how can we install enlightenment desktop on ubuntu linux? What is the use of installing that on existing kde or gnome desktops? How different is this from existing desktop versions?
Hi there Alan Farrer,
Enlightenment Desktop is a desktop manager that gives artistic and interesting effects in it (without burden in the system).
Enlightenment Desktop also provides options to suit the user's computer capabilities. Before getting into the operating system, users will be given the option to look of the desktop. Will be presented starting from the simplest to a more interesting (with the hardware that is not too heavy).
The libraries behind Enlightenment are referred to as EFL (Enlightenment Foundation Libraries) collectively, each with a specific name and purpose.
Enlightenment and EFL support several platforms, though Linux is the primary platform of choice for our developers, some make efforts to make things work on FreeBSD and other BSD’s, Solaris, MacOS X, Windows (XP, Vista, 7 etc.), Windows CE and more.
You can use Enlightenment on any ubuntu version or Ubuntu-Based Distribution.
To install Enlightenment on your Ubuntu follow these step below :
1. Run your Ubuntu and log on as root user
2. Launch terminal and add the PPAÂ Enlightenment on your Ubuntu with the following command
sudo apt-add-repository ppa:hannes-janetzek/enlightenment-svn
sudo apt-get update
sudo apt-get install e17
Make sure you are connected to the internet when you add the PPAÂ Enlightenment
3. When the process finish, log out from your Ubuntu and select Enlightenment session to log in.
