Enlist The Different Ways And Command To Check FSMO Roles
What is an FSMO role and tell me more about the five FSMO roles? What are the different and variant ways in which I can check FSMO roles? And what is the command for monitoring the FOSMO role?
Answered By 0 points N/A #320027
FSMO means flexible single master operations. FSMO role which is also called or recognized as operations master roles which supports you to check struggles in your active directory. Active directory is a repository that contains all the objects.
There are five types of FOMO roles which are: 1. Schema master, 2. Domain naming master, 3. Infrastructure master, 4. Relative ID master and 5. PDC emulator.
Various tools can be used, such as Solar Winds Server and Application Monitor.
Different ways to check FSMO are:
  • By using a command line tool.
  • Windows PowerShell ISE
