Hi Guys,
I need to know more details on Enterprise Gmail backup solution tool, which will be useful to backup and restore our emails to any email account from Google. Please do the needful for providing details on this regard and do let me know about, how to start working with the mentioned Tool.
Thanks,
Tyrone E Louis
I have a tool in mind for this, Backupify.
It’s enterprise SAAS solution for Google apps, Gmail, Calendar and other backups and restore.
Being a SAAS means the software is offered as a service to you at a cost for limited period of time, and with cloud space to access your back up on the go. But there is option for you to try out for free up your Gmail space.
points
There are various reasons behind thinking about the backup of Gmail emails. We know that Gmail is one of the widely used applications for better communication.Â
Accessibility of data into other email clients and the ability to save a copy locally necessitates the backup of emails stored in Gmail. For making the process lot easier, you need a Gmail email backup solution. It is one of that convenient and advanced software that makes a copy of Gmail emails into PST file format.
This utility eliminates the requirement of installing Outlook in the system while taking backup. If you need to exclude some emails from going into the process, the filter option comes in handy. It lets you create a batch backup of the Gmail accounts without setting any limits on the number of mailboxes. While processing the backup files, it also eliminates the risk of losing data. Talking about its compatibility, this utility can run on any Windows Operating system.Â
You can also explore its demo version through which you are allowed to backup/restore the first fifty items/ folder.
