Entry the new windows 10 from microsoft
I had the technology enthusiasts mention that windows 10 is due for release this year? Will windows 10 support the same pipeline as the predecessor 8 and 7? I can imagine because I heard that It will be installable in both the tablets and the computers at the same time. Will this Operating system require a particular hardware upgrade or the previous processors can support this? that is the Pentium 4 processors
Answered By 0 points N/A #192551
According to official sources below given are the system requirements for the Windows 10 version available:
Processor: 1 GHz or faster
RAM: 1 GB(32 bit) or 2 GB(64 bit)
Free HD: 16 GB
Graphics Card: Microsoft DirectX 9 graphics device with WDDM driver
A Microsoft account and internet access.
If you have the above mentioned configuration you should be able to use Windows 10. Anyway you may also be knowing that many of the things will not be compatible with the Windows 10 version and also screen resolution and other factors may be a little distorted.
Answered By 590495 points N/A #322337
Windows 10 is a series of operating systems produced and developed by Microsoft as part of the Windows NT series of operating systems. It is the successor to Windows 8.1 released to manufacturing on July 15, 2015 and to the public for retail sale on July 29, 2015. According to Microsoft, they will update Windows 10 in perpetuity instead of releasing a new operating system as a successor.
Windows 10 receives new builds on a regular basis which are available to users for free. Any user adopting Windows 10 can upgrade legacy machines straight from Windows 7 or Windows 8.x to Windows 10 without the need to re-image or do intrusive and time-consuming system wipes and upgrade procedures. One of the most notable features of Windows 10 is the support for universal applications.
It is an expansion of the Metro-style apps that was first introduced in Windows 8. The desktop interface of Windows 10 was revised to manage transitions between a mouse-oriented interface and a touchscreen-optimized interface that will be based on available input devices. Before installing or upgrading to Windows 10, you need to check if your machine is compatible.
Microsoft Windows 10 requires 1 GHz or faster processor, 1 GB RAM for 32-bit and 2 GB RAM for 64-bit, 16 GB free space for 32-bit and 32 GB for 64-bit, Microsoft DirectX 9-compatible video card with WDDM 1.0 driver or higher, and 800 x 600 minimum screen resolution.
