Has anyone of you tried running any Epson wireless projector Linux environment setup. One department here in our office uses mostly Linux. They just bought a new Epson wireless projector but not sure if it will work.
Epson wireless projector Linux compatibility?
It does not matter wheatear you use wireless or wired projector if you have wireless channel between projector and your pc. You just need to install the appropriate package of drives of that projector. You can install drivers from CD that will be provided with projector or you can download them from the website of that particular projector. I repeat that it will work with linux without any problem.
Thank you
First, optional wireless projector module needs to be installed. It will enable the projector to communicate through wireless with computer. But currently it can be possible only in Windows. Unfortunately in linux operating system, this type of wireless epson printer is not supported.
