Hi there,
Every time I open my PC this EPU-4 Engine message appears and I don’t know what it means and how this can be solved. I have no idea about this error and what is causing it so is there anyone who can help me to fix this one ? What is causing it ?
Thanks experts !
EPU-4 Engine
EAccessViolation.
OK
EPU-4 Engine EAccessViolation on PC
EPU-4 Engine is an optional power-saving feature in certain motherboards made by ASUS. This feature has two components: hardware (physical part) and software (program suite). The error you're seeing appears when the motherboard gets changed to one that does not support EPU-4 Engine but the software is still active on the machine. The solution is to remove the associated software from your computer by doing the following:
1. Click "Start" and then click "Run"
2. Type in %ProgramFiles% and press Enter.
3. Your Program Files folder will open. In it, locate the folder named "ASUS AiSuite" and delete it.
4. Restart your computer.
The error will not appear anymore.
