Is erd commander for USB iso freeware?
I am going to download erd commander for usb iso from the free file sharing sites like rapidshare or depositfiles. Does anybody downloaded it there and is it a  freeware or shareware, or just I need to buy?
Hello.
After a quick and a good research I found some websites which offering erd commander for usb.
That will be a trail version that can be used only for 30 days.
To download the full version you need to purchase the product.
Click on the below link to download erd commander for usb.
http://calmit.org/erd-commander-2010-vista-windows-7/
Thank you.
Hello Jody Akerly,
To download ERD commander for USB ISO free you can visit this link.
Here you can find the full version of the ERD commander as well as you can learn about many versions of this software.
If you want to buy this software from online. You can buy it from here download link.
It is a trial version that can be used only for 30 days. You can register this from online.
To register this software you have to purchase it from online.
Hope this link will be very helpful for you. Best of luck.
