ERP Database Error 49153
When you try to connect to your Sage 300 ERP application or access a Sage 300, this error is displayed. “Can not access the database (error 49153).” How can I solve this error?
To correct the above error in Sage 300, you must follow the following simple steps: In the Run command, type “Services.msc” and click OK. Look for SQL Server (SQL Express). If the status is Not Started, right-click and click Start to start the process. Once the Service Control pop-up window closes automatically, the following screen appears with the status Start. Once you log in to Sage, users can log in to Sage 300 ERP. This will solve your problem.
Notifications
