Error 0x000036b7 The Hexadecimal Format
Error 0x000036b7 is the Hexadecimal format. It is the error caused in the Windows code format which lets you know the mistake. It has a numerical error number and a technical description. This error occurs by Windows System file damage. It may happen as a result of corrupted files. You can solve this error by ‘downloading (0x000036b7) repair utility. Once its installed click scan, then the option will appear to fix error button. When the scan is completed, you may restart your computer.
Restart your computer and go to the administrator. Click start button then select all programs, go to Accessories, then system tools and then click system restore. In new Window, you will find “restore my computer to earlier time” click on that, then apply NEXT. Select the most recent restore system point, click on restore point then click next. Then click on the confirmation window and restart your window.
