Error 0x3 Patch Download Unavailable in Grand Chase
I got an “error 0x3 Patch Download Unavailable” when opening Grand Chase. I tried to restart my computer but it still didn’t fix my issue. Please help.
Hi
You are facing this error when you try to launch the .exe file of Grand Chase game. To resolve this issue, please try the following solutions below:
1. Uninstall the game and then remove all the components of the game and then reinstall it back.
2. Register the game by purchasing it from the Grand Chase website. And then follow the whole setup on how to configure it correctly. Do not use any key generators or attempt to use any illegal tools.
The “error 0x3: patch download unavailable” happens when the patch program is not able to connect properly to the update server. Here are some reasons and solutions for Error 0x3 when opening Grand Chase:
If the solutions above are not helpful, you may also want to visit:
It seems that the problem you are having is not an isolated one and there are a huge number of users who are also having the same problem. But fortunately, there is one user who suggested a possible fix on the patch problem. First thing to do is to configure the game to run in compatibility mode. To do this, right-click on the Grand Chase icon then select Properties. Select Compatibility tab and then check “Run this program in compatibility mode for” under “Compatibility mode”. Select “Windows NT 4.0 [Service Pack 5]”, click Apply then OK.
Next step, click Start, Control Panel, Network and Internet Connections, and then Network Connections. Right-click on the network connection you use to connect to the internet and then select Properties. Go to Networking tab, select Internet Protocol [TCP/IP] then select Properties. Under DNS, select “Use the following DNS server addresses” and then enter these on their respective fields:
These settings are for computers running on Windows XP and lower. For Windows Vista and Windows 7, go to these locations: Network Sharing Center, Change Adapter Settings, Current Network Connection, Properties, IPV4, and then apply the DNS servers below:
