Error 0x8001010e in Kodak Printer on Windows 8 Consumer Preview
I wanted to set up my Kodak ESP 725o network printer on Windows 8 Consumer Preview but got some problem.
The printer was being detected, but it gave me some error message: Operation could not be completed (error 0x8001010e).
What does the meaning of this?
Please let me know.
Thank you.
Error:
Operation could not be completed (Error 0x8001010e).
The application called an interface that was marshalled for a different thread.
Answered By 590495 points N/A #154820
Abort the installation then restart your computer. After booting the system, try installing it again and see what happens. If still nothing happens, try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit, Norton SystemWorks, or Norton Utilities. An error in the file system might be conflicting with the installation.
If it still doesn’t work, you should check your Kodak Printer’s installer’s system requirements. It is possible that the Kodak Printer’s application doesn’t support your operating system. You should check the manual that comes with your printer and other supporting documents of the setup disc that also comes with your printer.
