I encountered an error with MS Configuration Manager 2012 when deploying virtual machines. It says “Content location request for P0100021:1 failed. (Code 0x80040102)” Anybody knows how to correct this?
Error 0x80040102 with MS configuration manager 2012
Package with ID P0100021 are actually VMware Tools that may have been causing the error “P0100021:1 Failed” in your system when you try to deploy several virtual machines. Thus it is giving you the code 0x80040102. The code 0x80040102 meant that there is no content location that has been returned for the given or appointed package. To have this corrected, you just need to make sure that the specific package you are trying to deploy is sent to the right distribution point. After successfully deploying the said specific package to the right distribution point, the task sequence should finish successfully.
