Hello, I have been facing a problem installing Window 7 build 7000 Operating system. But the process has never been completed with window returning an error message that I do not understand? This is a sample of what actually happens. What could be the cause of the problem? Any ideas?
Error:
Windows cannot install requred files.Network problem may be preventing windows form accessing the file.Make sure the computer is connected to the network and restart installation.Error code:0x0070005
Error 0x80070005 on Windows 7 Build 7000 Installation
Here is the step by step process of how to download Windows 7 Beta Build 7000. But before we will start, first be sure that your computer is faster than 1 GHz processor. You must have more than 1 GB system memory to cater the installation of Windows 7 Ultimate. This is how to obtain genuine Windows Beta Build 7000. First, go to Microsoft TechNet website. Then, Sign In with your Windows Live ID. Copy the URL and paste it to your web browser where you used to log in to Microsoft TechNet. Then Windows 7 Beta 32-Bit Product Key will be displayed. Next step is to download, install and configure Virtual Box for Windows 7 Installation. First, download and install Virtual Box. After installing, run Virtual Box then Click New Button. Then, click Next. Select Microsoft Windows as your Operating System and Other Windows for version. Click Next, click New, click Next. Select Dynamically expanding storage and click Next. Select the size of your virtual hard drive and Click Finish. Install Windows 7 Beta Build in your Virtual Box. Click the Start Button on your virtual box. Wait for few seconds for the Windows to download files. Then install it, follow the instructions until the installation is complete.
