Error 0x800700c1 on installing apps with Windows 8.1
I've been trying to install apps on my Windows 8.1 through the Windows Store. However, whenever I attempt to do it, it is throwing an error and I was unable to install. I could not even upgrade apps since this same error is always appearing. What can I do to fix this? Please help me.
Something happened and this app couldn't be installed. Please try again. Error code: 0x800700c1
Try again     Cancel install
Best Answer by Sharath Reddy
Answered By 590495 points N/A #117551
Since you are using the newest version of Microsoft Windows, remember that there are not so much programs that support it. Before installing the program always make sure to check the system requirements to verify your system if it is compatible. Certainly, the Flipboard app is designed only to run on Microsoft Windows 8.1 and will not run on Microsoft Windows 8.
The app supports both 32-bit and 64-bit processor architectures. There are not many users that have the same problem with Flipboard maybe because Windows 8.1 has really very few users. If there are other programs running when you run the installer, try closing them and run the installer again. If this didn’t work, restart your computer and run the Disk Cleanup.
Swipe then go to Settings, Control Panel, Administrative Tools, and then double-click Disk Cleanup. Select drive C and click OK. Check “Temporary files” and other boxes you wish to clean, click OK, and then click “Delete files”. After that, restart your computer and install Flipboard again. Make sure you are really using Windows 8.1 because if it is Windows 8, you need to upgrade to Windows 8.1 because the app will really not work.
Answered By points N/A #117552
There are some reasons why you might be unable to install the app from the Windows Store. Maybe your preferences might be hiding apps or family settings hiding or this app is not available in your region or your PC’s processor is not compatible with the app or system requirements is not math with the app etc. Many way to can solve this problem.
  • Method 1
First of all be sure that the home location for your Pc is correctly set to your region. Go this site and here you will find all possible reasons solution which I have mentioned above.
If not fix your problem follow second one.
  • Method 2
Check the date, time and time zone is set according to your time zone.
1. Press “Windows key+C”.
2. Type “Date and Time”.
3. Click “Change date and time” button.
4. After changing date and time click “Apply” and “OK” .
After that if problem persists follow this steps.
  • Method 3
Clean Store Cache.
1. Press the “Windows Key+R”
2. In the dialog box type “WSReset.exe” & tap on “OK”.
3. You can see “The cache for the store was cleared. You can now browse the store for apps.”
Also you can check if the issue persists you can perform a clean boot in Windows. To perform successfully a clean boot visit this site and get the idea.
Hope after that you will not face any problem.
Answered By 0 points N/A #117553
Hi Conrad Mckay
Side by side these solutions also pay a visit this Techyv post too to get more idea because this post is also addressed your problem.
After few windows update get this error 800700C1
