Paul Adam
Posted on - 07/31/2011
I have owned a 6680 a couple of years now but have never succeeded to run the backup operation.
My PC is at the time running Windows XP Pro with Service Pack 3 (had exactly the same problem with SP 2).
Whenever I try to run the backup operation I just keep getting the following error message:
"Nokia Content Copier – A fatal error occurred during the backup. Error code: 0x80400005"
I have searched everywhere for a solution to this 0x80400005 error but it seems very hard to find.
I have the latest PC Suite Software, version 6.86.9.3. Now I hope that someone out there can help me.
John20
Error 0x80400005 when backing up my Nokia 6680
Follow these steps you can solve your problem.
Change your phone profile mode to ‘General’ and select ‘Manage’ from ‘Tools’. and select uninstall PC Suite support from your phone, again you need to install the PC Suite support by using Nokia PC Suite computer programme.
After finishing the installation please restart your phone and try backup again.
Note: Please leave your phone on ‘General’ profile mode while doing the backup.
Enjoy!
I can help you fix the issue with the Phone back up.
I suggest you to follow these steps:
Try creating the back up to a different location.
Now, try changing the backup content.
Remove the memory card if any inserted in your phone.
Also, make sure date and time on your computer and your phone is correct.
Now try to back up.
It should work fine.
IÂ suggest you to follow these steps:
Phone.
Your phone is correct.
Now try to back up.
