I am trying to scan my computer with Microsoft Security Essentials, but an error pops out stating that it couldn’t scan my computer. My computer is up to date so I really don’t know why the error is showing.
The error code is 0x8050800c.
What should I do to fix this?
Microsoft Security Essentials couldn’t scan your computer
An unexpected problem occurred. Install any available updates, and then try to start the program again. For information on installing updates, see Help and Support.
Error code: 0x8050800c
Error 0x8050800c with MS Security Essentials
The error code 0x8050800c states that system prohibits or stops the scan from running in a certain user content. In this case you may restart your computer, and retry the scan. If the issue persists, you may want to try to change the scan destination file or drive to isolate the issue further. If it’s still the same, then try to update your computer again through http://update.microsoft.com/windowsupdate/v6/default.aspxor try to reinstall the Microsoft Windows Malicious Software Removal Tool through http://www.microsoft.com/en-us/download/malicious-software-removal-tool-details.aspx. If you are still getting the said error code after trying the above solution, then please try the steps below:
Go to Start, click on Run and type %systemroot%debug, then hit OK
Open the file mrt.log
Look for the recent entry on the log file.
Follow the instructions the recent entry of the log.
If possible, also try to run a full scan of your system.
There’s no problem with the real-time scanning of Microsoft Security Essentials, the status says that your computer is still protected. Your only problem is when you are doing a manual scan of your hard drive. Try following what is suggested in the dialog box. Update Microsoft Security Essentials. If updating the software did not help, try checking its settings. Make some changes on the settings. Do a trial-and-error in changing the settings to isolate the problem.
If disabling and enabling some options did not give a good result, try uninstalling the application. You can still download it again from Microsoft’s website. When the application is completely removed from the system, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities or Norton SystemWorks.
If you still have the installer for Microsoft Security Essentials, install it then try doing a scan again. If you don’t have the installer, you can download it at http://www.microsoft.com/en-us/download/details.aspx?id=5201.
Choose the right version for your Windows.
