Error 0xc0000006 on my HP MediaSmart Webcam
I have a HP MediaSmart Webcam but I cannot start it properly. It always show an error 0xc0000006 every time I try to start it. What can I do to fix this?
Hello.
Make sure that you have good compatible software which acts as an interface between your web cam and computer.
And also check whether the driver of the webcam is installed without any errors.
Try to re install the driver and check for the compatibility of the driver with your operating system.
Contact hp customer care for further support.
Thank you.
Application failed to initialize 0xc0000006 error occurs if your computer is missing the .NET Framework. To fix this issue. simply download the missing .NET Framework on the link below:
http://www.microsoft.com/en-us/download/details.aspx?id=17851
And also, ensure that your driver for your HP MediaSmart webcam is properly installed. And your camera is properly connected.
