I was trying to install AVG 2012 Free Edition for numerous times now but there seems to be a problem with the connection. The error code is “0xE001003D”. The error message is “Specified file was not found” with additional message of “An internal MSI Engine error occurred”. How can I fix it?
lee hung
75 points
Error 0xE001003D on AVG 2012 Free Edition Installation
Please disable Windows defender first.
Your situation is caused by some issue with access rights and it got fixed in Beta version.
Signing up for beta and downloading installation package only takes a few minutes. You are not required to take any action / do any actual testing after you sign up. You can simply download the beta installation package and use AVG as usual
Please install last beta build.
Hope this will fix up your problem.
