Error 1003 occurred at an Open VI reference in calling vi. VI
My SubVI is not compiling due to some errors and also it’s having a broken run arrow. I am also using Static VI Reference to call a SubVI. But, my calling to VI does not have a broken run arrow. Why does a broken referring to SubVI instead of calling VI?
Main Software: LabVIEW Development Systems>>LabVIEW Base Package
Main Software Version: 2011
Possible reason(s):
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Select File>Open to open the VI and then verify that you able to run it.
VI Name: add. VI
