Error 1008: Ghostscript timed out
Asked By 1300 points N/A Posted on -
Hello people,
I am at work place making some price quotation on a project using ms word, when I am finished with the quotation, I want it to be saved into a PDF file as what is required.
So discovered that Bullzip is capable of printing to file feature, so I used Bullzip to print it to a PDF file, when I am in the process of printing my proposal to PDF file, I meet an error,
Please see below the error message.
Bullzip PDF Printer
An error occurred.
Make PDF
I am not familiar with this error message, this is my first time to see such error, please help me fix this error, thanks a lot.
Answered By 15 points N/A #122921
Dear Mattewgems,
This error has been fixed now and I am giving you two solutions for this error.
Solution 1: Find settings.ini file in C:Program FilesBullzip folder, open settings.ini file in notepad and add the line into the settings.ini manually.
GhostscriptTimeout=600
It will give you 600 seconds timeout, which is equal to 10 minutes and your files will be printed smoothly.
Solution 2:
1. Open notepad
2. Write in notepad file
[PDF Printer]
; Set Ghostscript timeout to 100 minutes
GhostscriptTimeout=6000
In the body, the spacing has to line up otherwise it don’t work. You had to manually add the spacing to make it work.
3. Save file as global.ini
4. Go to C:ProgramDataPDF WriterBullzip PDF Printer
5. Copy that global.ini file into Bullzip folder.
Now you should be able to print without getting the time out error message.
Hope this helps.
Cheers
Benth
