Error 105 Unexpected End of Data on Retrospect
One of my clients has an issue using a particular USB disk drive for backing up. He is receiving the error “Error-105 unexpected end of data.” on Retrospect Multi Server version 7.6.123. I have tried re-cataloging but failed. I did chkdsk /r which completed successfully. But on starting Retrospect again, it failed. Why is it caused using on this USB? How can I get this solved?
Answered By 80 points N/A #118366
Hello Henry,
Basically, error 105 is a problem indication related to the media that you are using. Retrospect error 105 occurs if power failure interrupts or crash the tape drive or back up computer. I suggest you to try another piece of media. Use a Travan tape. You also had to delete the backup set and recreate the backup set. If the first solution won't work you can visit the site for more information.
Regards, Zorian
