Error -1074118643 occurred at niRFSA Commit.vi
Posted on - 03/13/2013
While attempting to exercise the NI PXI-5661 with the NI-RFSA drivers in LabVIEW an error occurs which you can see in the below attached image.
How can resolve this matter?
Possible reason(s):
Device not available in NI-RFSA. The device may be being used by NI-Tuner or NI-5660, or the device is being reset. After using a device in NI-Tuner) you must reset the device with the Reset Device button in Measurement & Automation Explorer before using it in NI-RFSA,
Status Code: -200324
Continue
