Error 113 occurred at UDP Write in TCT File server.vi
I am exercising to create a client-server file relocate application. The client understands writing a file accumulated on a provided tasking location (PC) and delivers it to a server installed on one more tasking location for extra practice. I am exercising UDP as the transport protocol (TP).
The issue is that my application practices completely with files whose volume is in the series of kilobytes, on the other hand while I do attempt to deliver files whose volume is in the series of megabytes, the applicable damages down and I received an error message. I felt that I have to maximize the volume of both the UDP delivering and getting buffers, on the other hand I do not knowledge how to perform. How can this matter be solved? If somebody has an idea please share thanks.
Possible reason(s):
LabVIEW: A message sent on a datagram socket was larger than the internal message buffer or some other network limit, or the buffer used to receive a datagram was smaller than the datagram itself.
Continue
