Whenever I try to connect using the Citrix Online Launcher, I get 'Error 12029 sending request to server download.citrixonline.com. A connection with the server could not be established'. I tried to uninstall and reinstall it then attempted to connect again and the same error occurred. I'm thinking it could be a firewall issue but I couldn't be sure.
Error 12029 encountered in Citrix Online Launcher
The above error message will be showed if the Citrix Online Launcher is incapable to connect to the suitable server for a joining. This error would typically designate either a network or else firewall issue, though it can correspondingly present itself if the fitted Citrix Online Launcher is not properly updated.
To decide the cause, first eliminate the Citrix Online Launcher:
Tick Start
Tick Control Panel
Tick Add/Remove Packages, Uninstall a Program or else Programs And Features
Tick to highpoint Citrix Online Launcher
Tick Change/Remove, Eliminate, or Uninstall
When the Launcher has been eliminated, try the connection again
