chelsea cox
Posted on - 11/06/2011
During the set up trial of Microsoft Office Professional 2007, I encountered Error 1317 in which I cannot create a folder and the path doesn't exist. Â Is there something wrong with the program or in my PC? Please help me find a solution for this.
Error 1317 on setting up MS-Office Pro 2007
Hello Chelsea,
You need a proper permission set up of the folder to be able to solve your issue. You can do the method below to be able to fix your problem:
- Go to My Computer
- Select properties after clicking the parent folder which contains the error
- Choose security tab
- Security was set to full control so you need to make sure that the administrator is listed and permitted
You can also follow the steps below to be to repair the error:
- Download MS office professional 2002 repair tool and install
- Scan your computer for free by clicking the repair all button
- Repeat clicking the repair button
- Done
Go to this link to download repair tool.
Zorian
Trevor
 Microsoft Windows 7 was equipped with a lot of security options that sometimes makes as crazy because of security errors that we have received. Installation requires an administrator account to run the installation software. You may also try to right click the setup.exe then select run as administrator on the pop up menu.
Please check also if your installation disk in hand is the original installer from Microsoft. There are so many installation disks today that is pirated that looks like original installation disk. Pirated installation disk sometimes contains error. Better to have the original installation disk so that you may have the full support from Microsoft.
