Error 1406 in software installer
Hi
I want to install a software on my pc but I failed. Windows show a error. Why I see this error message?Anybody knows it?
"Error 1406.Could not write value Icon to key/software/microsoft/internet explore/extensions/{C1994287-422F47a8E5E-6323E210A125}. Verify that you have sufficient access to that key, or contact your support personnel".
How i can fix this problem?Please help me to solve this error. i am really upset for this problem. Thank you
Best Answer by Kirkpatrick Crystal
Answered By 0 points N/A #124315
Hi Konakhatun,
Your system lacks the necessary permission to access certain registry keys.
To solve this, you need to enable full control of the registry. Follow these steps:
1. Login to your PC as an Administrator. This is very important to gain access to all registry keys that need to be configured
2. Go to START > Search for Regedt32
3. Click on the Icon to Open Registry Editor
4. Select & Expand HKEY_LOCAL_MACHINE folder, then right click on SYSTEM folder and select Permissions…
5. In the Permissions window, tick Full Control and Read boxes for all users in your PC
6. Select OK and Exit the Registry
7. Reboot your computer and Retry
Answered By 0 points N/A #124316
Hello Konakhatun
Try the following solutions in the order presented to resolve the issue.
1. On the windows taskbar,click on the windows icon.
2. In the start search box ,  type msconfig and then press enter.
     In the user account control windows open with the message windows needs your permission to continue, click continue to        close the window.
3. In the system configuration window, click  the startup tab and then click disable all.
4.Click the services tab, click the hide all microsoft services checkbox and then click disable all
5.click apply and then click ok.
6. when promoted restart the computer , click restart.
Answered By 590495 points N/A #327326
This error appears to be related to permissions. If you are installing ZENworks, make sure you are installing with an administrator account. If you are installing with a limited or non-admin account, ask someone with an administrator account on the computer to install the program for you.
If you are in a LAN or local area network and you need this program, ask the network administrator to install the software for you. If this doesn’t apply or you are not in a network or you have an administrator account, check the program’s system requirements and verify that your computer meets those requirements.
If this doesn’t work, run the installer or the setup file as admin to give full permissions. Right-click the ZENworks setup file then select “Run as administrator”. If this doesn’t work, download the latest free trial, ZENworks Suite.
The latest version at the moment supports Windows 7 Service Pack 1 (Professional, Ultimate, or Enterprise edition), Windows 8.x (Professional or Enterprise edition), and Windows 10 (Professional, Education, Enterprise, or Enterprise 2015 LTSB edition).
