Error 1430 when running the Vi Analyzer
I am getting an error 1430 when running the VI Analyzer.
The VI Analyzer worked fine until early this morning. I turned off the LabView since it was running overnight, then I launched the VI Analyzer and I get an error 1430. The LabView version I am using is version 10. I am not very familiar with what the error message means. Does anybody know what the error stands for and how can I fix this problem. I would appreciate any help I can get from you guys.
Error:
Expand the tree elements to find out which Vis could not be loaded and which tests could not be run.More details about the errors are given in the box below.
Error 1430.The patch is empty or relative. You must use an absolute path.
Test Path: C:Program Files National Instruments LabView 2010project_VIAnalyzer_testsComplexity MetricsModularity Indez.llbVI Path: C:UsersthegemanDesktopFinal Inspection Project 2010Source CodeWireless ModemCOTS Subpanel.vi
