Error 15635 on using Configure Distribution Wizard in MS SQL
I used the Configure Distribution Wizard in my MS SQL Server 2005 to setup its distributor.
However, I end up with this error box. How to get rid of this and what is the possible fix?
Detach database failed for Server 'Instance Name'. (Microsoft.SqlServer.Smo)
Additional information:
An exception occurred while executing a Transact-SQL statement or batch.
(Microsoft.SqlServer.ConnectionInfo)
Cannot execute 'sp_updatestats' because the database is in read-only access mode.
Cannot DETACH a database snapshot. (Microsoft SQL Server, Error: 15635)
