Error 1606 with Autodesk AutoCAD 2014
Hello friends,
I don’t know why I am getting this kind of installation problem. Original version of Autodesk AutoCAD 2014 with a license bought from store. While Installation I got this error message ‘could not access network location’ system is not in network, I am administrator and user. Why I am getting this error, please explain. Your help is appreciated.
Image of the Error
Error Message in the Image
Error 1606.Could not access network location AutodeskAutoCAD2014R19.1.
Answered By points N/A #179315
This problem indicates to a bad registry that has become misconfigured. So this error is appearing.
1. Go to Start menu >> type “regedit” >> hit enter to open “Registry Editor”.
2. Navigate to the following section: HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerShell Folders
3. Check the path indicated by “Common Documents”. It will be pointing to a non-existing location. For example, “Common Documents"="C:UsersPublicDocuments”
4. Change the value data of the registry. For example, "Common Documents"="d:UsersPublicDocuments".
5. Instead, you can create the non-existing path instead of changing the value of the registry.
Now your AutoCAD 2014 setup will run seamlessly.
