“Error 17058” starting SQL Server (MSSQLSRVER) service on SharePoint Server
We are upgrading from MOSS 2007 to SharePoint 2010. I have made a SharePoint 2010 development server. All SharePoint elements are available on this server. As like SharePoint 2010, MSSQL Enterprise is also installed here. I have added “attach database”, copy of a database, from our MOSS 2007 environment.
All was functioning well. It was as a template used in an ESXVM ware environment for a series of developer SharePoint. The server was exactly the type that we want, so we made a template of the original server and for future use we made a new virtual server from the template along with a different server name. But it didn’t respond. I work with STSADM-o re-name server and worked fine. Now what is happening is that SQL Server (MSSQLSERVER) services will not respond. The error message in the event log is like the following:
The SQL Server (MSSQLSERVER) service terminated with service-specific error %%17058.
I have made a tour at c:/ProgramFiles/Microsoft SQL via command prompt.
Servermssql10_50.mssqlservermssqlbinn.
I also try the command "sqlserver.exe/c". Then I found the following error:
2011-11-07 09:52:14.49 Server Error: 17058, Severity: 16, State: 1.
2011-11-07 09:52:14.49 Server initerrlog: Could not open error log file 'E:MSSQL10_50.MSSQLSERVERMSSQLLogERRORLOG'. Operating system error = 5(Access is denied.).
I am using a local administrator account. Can anyone give me an idea where I can start from? For the need of upgrading to SharePoint 2010, we need to make this individual SharePoint environment. May be we have to change some of our web parts?
Thanks in advance.
