johnsteve
Posted on - 08/11/2011
Hi friends, I am in the process of installing Microsoft Frontpage on my computer via the network. In the middle of the installation process, I receive an error message (see below) and the installation fails.
Microsoft Office XP Professional with Front Page
Error 1706 Setup cannot find the required files. Check you connection to the network, or CD-ROM drive. For other potential solutions to this problem, see  C:Program FilesMicrosoft Office101033SETUP.HLP.
I have  tried installing it locally, by using my own CD drive, but I get the same error.
Please help. Thanks.
Error 1706. Setup cannot get the required files. Look at your connection to the particular system, or even the CD-ROM drive. For additional help, see C:Program FilesMicrosoft OfficeOffice101033Setup.hlp. Remove Office using add/remove programs. Examine Office Compact disc for "offcln.exe". Work document from search Window, and remove just about all office files. Occasionally missing or corrupt files can be a sign of faulty memory space. Run a Memory check on your pc.
Windows installer is not able to find the source data files to run the setup. The particular network administrative installation has stopped being available to you. You are attempting to utilize a workplace CD-ROM when you're prompted from the Home windows Installation technician to have an Office supply area. Click Terminate in order to put the particular CD
