Error 1719: Unable to Access Windows Installer on Citrix Receiver
Hello TechyV buddies!
I have installed Receiver Enterprises Edition using a command line which works well.
Here is the command that I have used:
“CitrixReceiverEnterprise.exe /silent /includeSSON SERVER_LOCATION="https://myserver/Citrix/PNAgent/config.xml" ENABLE_SSON="Yes" STARTMENUDIR="Citrix"
However, every time I add it as post installation task on my windows 7 scripted install image using the Kace K2100 deployment Appliance, I often encounter an error:
“Product: Citrix Receiver(USB) — Error 1719. The Windows Installer Service could not be accessed”
It only shows that it was installed just half of it and It is not functioning. It also doesn’t show up in the program files and features in removing it don’t show up.
Can anyone tell me what went wrong with the installation or what could have caused this problem?
I would appreciate any help. Thank you!
Print service error 808 followed by a 372 error
