Error 1722 in active directory
Hi, I am using windows 2003 in my computer. But yesterday I stuck in a work in active directory that was telling that operations failed with Error 1722. I reinstalled the program but failed to solve the problem. Looking for some help from you. Do you have any idea?
Answered By 590495 points N/A #152185
If you are already doing this before and this is the first time it happened, stop whatever you are doing, close any applications that are currently open, restart your computer then try it again. Check every program that you are previously using if the previous problem will appear again.
If the error pops up again on your screen, try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit, Norton Utilities, or Norton SystemWorks. You should also verify if the error appears only on one particular application. If after checking all the programs you are using you are sure that the error appears only in one of your programs, try reinstalling the affected application to possibly fix any corrupted files that may have developed in the system. See if this fixes the problem.
