Error 1731 in Office 2010
Dear,
Error 1731 means there is an issue with the Windows Installer Package of your MS Office Suite 2010. To fix this, you need to uninstall the existing Office Suite version installed in your computer. And then create a new folder in your desktop and copy the entire contents of your MS Office Professional Plus 2010 from the disc on this folder. Double-click the setup.exe on that folder and install MS Office.
Thank you.
Dear User,
You can easily solve this problem by uninstalling the previous versions of office suite from the computer.
And when uninstalling make sure the previous programs are completely removed. If the windows uninstaller doesn’t allow you to uninstall it,
You can use a third party software to uninstall such as,
https://www.revouninstaller.com/revo_uninstaller_free_download.html
Thank you
Notifications
