david allen
10 points
Posted on - 09/16/2012
I got an “Error 183 occurred during installation. Please Try running setup again” on my Bluesoleil running on my Windows 7 Ultimate 64-bit PC. This happens while finishing the installation. Will you please help me on resolving this?
Error 183 on Bluesoleil Installation
Hello
Error 183 refers to the compatibility issue of the software. The version of bluesoleil you are trying to install may not be compatible with your current operating system. Try to download the software which is compatible with your operating system ie. windows 7 ultimate.
To download the software for windows click on the link below.
https://bluesoleil.en.softonic.com/
Hello Allen,
Before doing anything simply restart your system at first and try to install it again. If the error remains, that means the Bluesoleil setup application is corrupted somehow so in that case, you can download it again or try to get another setup. The other reason of this error could be the compatibility issue because if your system is not compatible with the Bluesoleil setup then it won't work. Hope this will help.
Good luck.
