Error 183 with partition magic? Help!
Hi , using partition magic I was trying to add a 15 GB partition in my 250 GB hard disk. Partition magic suggested me to reboot my pc for completion. But after rebooting I am getting a problem that is showing ERROR 183. It was not allowing me move forward, so I couldn’t do anything. Can I have some information from you to fix this?
Answered By 5 points N/A #153809
Partition Magic Error 183 is normally caused by corrupted Microsoft Windows system and results in collapsed system data files. Considering the several situations which cause file corruption .
i.    An incomplete installation
ii.   Failed file removal
iii.  An awful deletion of utilities or hardware
 Therefore, I suggest you performing the following solution below :
1.    First of all, please log in to your system as an administrator
2.    Go to Start , and navigate to : All Programs>System Tools>Restore
3.    A System Restore window will be displayed . Then , click on Next button until you find “Restore my machine to a
      previous date” , and click Next.
4.    Choose the latest system restore date from the “Select A Restore Date” list , and select Next.
5.    In the confirmation window, please continue the process by clicking on the  Next button
