I got Microsoft Office Professional Plus 2010 for my personal computer. I have Windows 7 Home Premium 64 bit. While I attempt loading Office I receive an error message which you can see at below attached image. I need your help to resolve this. Thanks in advance
Problem: Error 1920. Service ‘Office Software Protection Platform’ failed to start. Verify that you have sufficient privileges to start system services.
Hello, I see you are using Microsoft Office Professional Plus 2010. This problem is quite common in this version of Microsoft Office. Please Open Command Prompt (cmd). In that type the following and press enter:
“C:Program FilesCommon FilesMicrosoft SharedOfficeSoftwareProtectionPlatform” /grant “Network Service:F” /t
Once you have done this, Install Microsoft Office 2010. Good luck!
To solve the problem, follow the given procedure:
Click start-> Control Panel -> Administrative Tools -> Active Directory users and Computers -> Expand YourDomainName (left pane under Saved Queries) -> Click Users -> Right click RTCHDomainServices (right pane) -> click Properties -> click Member Of -> Click Add -> Type Administrators (in the Select Groups dialog box) -> Click Check Names and click OK two times.
After that run the setup again.
I Hope This will solve your problem.
Good Luck.
