Error 1935. An error occurred during the installation of assembly component.
Hi there,
When I try to install Microsoft Dynamics NAV 5.0 SP 1 on the machine and the operating system is Microsoft Windows 7, an error message is received. The error code is 1935. Please find below the screenshot for your reference.
Does any expert know the solution and help me to fix this error please? Thank you very much.
Microsoft Dynamics NAV 5.0 SP1 CSIDE Client Install. Error 1935
Microsoft Dynamics NAV 5.0 SP1 CSIDE Client Install…
{98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}
HRESULT: 0X800736CC
Best Answer by Spreckelmeyer Kayla
Answered By 0 points N/A #175730
Hi James,
I must say Microsoft Dynamics NAV 5.0 SP 1 is a dynamic software. The error code 1935 that you are getting has its own meaning and reasons. Some of the reasons are you didn’t install MS SQL Server as a part of the MS Dynamics NAV installation options. To overcome this problem it’d be better if you install Microsoft Visual C++ 2005 Service Pack 1 ( Redistributable Package ). You can find MS Visual C++ from the following site:
http://www.microsoft.com/en-us/download/details.aspx?id=5638
Good Day.
Answered By 0 points N/A #175731
Hi.
To resolve that problem you need to perform full update of your system and you have to download and install Microsoft Visual C++ 2005 Service Pack 1 x86. X86 version of this packages has to be installed even if you are installind Dynamics NAV on x64 PC. Microsoft Visual C++ 2005 x86 can be fount on following link Microsoft Visual C++ 2005.
Queen Norman
Answered By 0 points N/A #175732
When you encounter this error, it means that the Microsoft Windows Installer had an error over trying to install assemblies to the Global Assembly Cache(GAC) or the Win32 GAC. To solve this You need to clear the transaction log:
1. Run The command Prompt as Administrator. Go to Start, All programs, Accessories, then right Click Command Prompt and select Run as Administrator
2. In the Command Prompt type in the following:
     fsutil resource setaoutoreset true C:
This assumes that drive C: is where you have installed Vista. If not insatlled on that drive, for example D:, change it appropriately.
3. Restart the system
4. Install the program again
If this didn't solve the problem, maybe an antispyware, antivirus. To solve This:
1. Disable your antispyware and/or antivirus properly before installation
2. Install again. If this didn't solve this,
3. Remove any spyware or adware using taskmanager's processes tab. for example, the "wtools.exe".
I hope this solves the problem
Answered By 10 points N/A #175733
Hi James D Guerrero
Check out this Techyv post "Top 10 Windows 7 Errors". Here you will get your problem's solution as well you can broaden your knowledge by gathering huge information regarding on Windows 7 errors.
