I can’t install at all my Nokia phone driver. This error appears every time when I want to install the driver. My PC is up to date, drivers also and this is the latest version of installer. Does anyone experienced this error before ? What is the solution ?
Thank you !
Something’s gone wrong
Error 1935. An error occurred during the installation of assembly component {303994BA-6487-47AE-AF1D-7AF6088EEBDB}. HRESULT: 0x8007422
OK
Error 1935: Error Occurred During Installation of Assembly Component 0x80070422
If you are installing Nokia PC Suite, make sure you meet all the requirements. Don’t install old versions because sometimes newer operating systems such as Windows Vista and or Windows 7 are not supported. There are actually different Nokia software available. If one doesn’t work or doesn’t install on your computer, you can try the remaining applications.
I’m sure there is one that will work on your computer. If you are installing Nokia PC Suite but an outdated version, try downloading Nokia PC Suite 7.1. It supports Windows XP [Home or Professional] Service Pack 2 and up, Windows Vista, and Windows 7. Since you haven’t installed it yet, download and install this version instead.
If it doesn’t work, try using Nokia Care Suite 5.0. It supports Windows XP, Windows Vista, and Windows 7. Windows 8 is not supported. If it doesn’t work either, you can also try Nokia Ovi Suite. It supports Windows XP [Home or Professional] Service Pack 2 and up x86 only, Windows Vista [Home Basic, Home Premium, Business, Enterprise, or Ultimate] Service Pack 1, and Windows 7 [Home Basic, Home Premium, Professional, Enterprise, or Ultimate] both x86 and x64.
I’m sure one of these three applications will work on your computer.
