I am trying to install Quicken Starter Edition 2012 to make budgeting easy on my Windows XP computer. The problem is I keep getting an error code 2 during the setup. And then the installation will stop leaving me no choice but to start the installation again. But every time I am starting the setup, the error keeps appearing that’s why I could not continue. How can I resolve this issue?
Error 2 on Quicken Starter Edition 2012
The problem may be caused by the Quicken application not being supported by the operating system that you are using; especially in this case you are trying to install a starter edition. I will therefore suggest that you try the following:
Instead of the Quicken starter edition, search the internet for the full edition and download it and then install it and see what the response will be.
You will also need to check the system specifications and make sure that the Quicken application that you are installing meets the system requirements of your computer.
Also try restarting the computer after closing all the running applications in the task manager and then try reinstalling the application.
-Thompson Locker
