freakybj
Posted on - 12/23/2011
I am developing my office website.
Everything runs smoothly except when I tried to change the logo, I got an error 2038 on my screen.
The original logo is a .gif file and I am trying to change it with .png file.
What does the error means and how can I fix it?
Error 2038 with image file
What web page design/ develop program are you using to develop your office webpage?
When any image file is missing from its web page folder, this error s generated. You have to change the image code according to the web page design program you are using to develop your webpage. Â
If you are using HTML, then change the code which represents the logo original.gif to original.png. It should like this: <img src="original.png" alt="original" width="304" height="228" />
If you are using HTML+CSS/Other programs- code for changing your image may be different. Sometimes the Web page designing software needs to rewrite the total coding line for image change. Then it can properly recognize the new image & it is also displayed in your PC browser. If you write the code for the new image properly, then you will be free from error 2038.
Regards
Crawly Math
Please download and install ReimageRepair Software on your system then you will be able to fix the Error 2038
