Error 2041 when encoding videos to MP4
I need to split a movie file so I can burn it with my DVD-R disk. What software can I use to for this? When I encode DVD to MP4 this error appears: “Error -2041: An invalid sample description was found in the movie.” And also, I cannot play any videos on QuickTime Player. How can I adjust the settings for this? Help please.
Best Answer by Paul Mac
Answered By 10 points N/A #107307
There are several softwares that you can find on the internet for splitting video files but I will recommend that you try using the following:
  1. Easy Video Splitter, which you can find by accessing the following site: http://download.cnet.com/Easy-Video-Splitter/3000-13631_4-10176687.html. The application is extremely easy to use and will offer you a high degree of control over the chopping process. You will find its interface to be aesthetically pleasing and it provides a large preview window on its left side. You can use it to AVI, WMV, or MPEG video files, and you can also be able to choose the stop and end points of your segment by simply clicking two icons.
  2. Another application that I will recommend is HJsplit. This one too you can get for free on the internet, you will just need to Google or your favorite search engine and look for it.
-Thompson Locker
Answered By 0 points N/A #107308
 “AVS video converter software “can be used for splitting DVD video into chapters.
Step1: Download the AVS video converter software.
Step2: Install the software.
Step3: Run the AVS video converter.
Step4: Browse the DVD file you want to convert.(click on browse button).
Step5: Go to format tab and click on “to DVD” to select DVD mode to be created and select on one present profiles from video disk types (profile).
Step6: The arrows buttons below browse can be used to change the sequence of the files.
Step7: You can remove or add files using (+/-) buttons provided below browse button.
Step8: Click on” Browse” button above the “advanced >>” button to select a location on your system.
Step9: Click on “Edit” Button.
Step10: In the “edit file” click on “Chapters” button. If you want to burn several files to DVD click on “Auto set chapters”. Select any one option “At beginning of each clip”, “At a time Interval”, “As a input file”.
Step11: click on “Add Chapters” to add chapters.
Step12: Click on “Disc menu” to start editing your DVD menu.
Step13: Select on menu style by double clicking on it, “add a video or image to the working area”,In settings window you can change “Menu Title”, ”Background music” and “Number of chapters on page” and click ok.
