Hi Tech savvy,
After the upgrade to latest version Adobe Flash Player 10, I get this error message. While I am working in an existing project, I got a weird error I did not see this error before. Did I make anything wrong during my upgrade? Please help me to resolve this error and to find solutions. Thanks a lot.
Error #2044: Unhandled securityError:.text=Error #2048: Security sandbox violation.
At com.metacafe.portal::OpenAdsBeaconDispatcher/callBeacon()
At com.metacafe.portal::OpenAdsBeaconDispatcher/set beaconURLS()
At com.metacafe.portal::PortalVideoPlayerBase/dispatchOpenAdsBeacons()
Error #2044 Unhandled security Error occur
If the only thing you did before the error happened is update Adobe Flash Player then the installation is probably corrupted. If you downloaded the installer for Adobe Flash Player, uninstall Adobe Flash Player, restart your computer, and then run the installer again. If there are no other issues on the computer, Adobe Flash Player should work properly. Try accessing metacafe again and see if it works.
Since you are still using Adobe Flash Player 10, I think you need to further update it because it is a very old version. Users today are already using Adobe Flash Player 13 just like me. If the website uses a much recent version of Flash Player, you might encounter a problem accessing the site because of your version.
The features required by the website or by the video you are playing are not available on your Adobe Flash Player. To fix this problem, download the latest version from Adobe Flash Player 13. It supports Mac OS X 10.6 Snow Leopard until Mac OS X 10.9 Mavericks.
