Error 25001 You seem to have Bitdefender antivirus installed
Hi there,
While I was installing BluStacks on my PC this error appeared during the installation. On the website I didn’t find anything about this incompatibility issue. Any solution ? Do I have to change my Bitdefender antivirus ? Is there any way to skip this ?
Thank you !
BlueStacks installation failed
Error 25001. You seem to have Bitdefender antivirus installed. BlueStacks is currently not compatible with Bitdefender. Installation will now abort.
OK
Answered By 590495 points N/A #173177
I think the message in the dialog box is clear enough for any user to understand. You will not be able to install BlueStacks as long as Bitdefender antivirus is running on your system. And even if you disable it temporarily just to be able to install it, it is still not possible. Detecting the antivirus doesn’t limit itself as to whether the program is running or not.
If you really want to use BlueStacks, replacing your antivirus would be the only solution. You can try Norton Internet Security. It offers a free 30-day trial period. It supports Windows XP, Windows Vista, Windows 7, and Windows 8. For Mac users, you can use Norton Internet Security 5 for Mac. It also offers the free 30-day trial period.
It supports Mac OS X 10.7 Lion, 10.8 Mountain Lion, and 10.9 Mavericks. Aside from Norton Internet Security, you can also try ESET NOD32 Antivirus. It also offers free 30-day trial period. It supports Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 8.1.
