robfloyd512
Posted on - 08/02/2011
Here is the problem. I tried to install Microsoft Office 2003 in my Windows XP computer. There was no error message when I tried to install it, but when I ran the program, a pop up message saying "Error 25090" appeared.
I tried to search it on the internet but nothing works. Tried re-installing it and also upgrade my Service Pack from 2 to Service Pack 3.
Is this an issue with Office 2003 and XP? It works in my laptop running Windows Vista.
sikandar
Error 25090 when opening Microsoft office
Your mechanism concern more often than not occurs when the previous Microsoft Office workings are damaged. To rectify the thorough fault, I recommend that you yourself fit the update.
For your easiness, I have scheduled the steps below:
1. Please download the update to the desktop.
2. Security Update for Excel 2003 (KB905756)
3. Double click the downloaded update to install them
• Note: make sure your Office 2003 CD accessible as you can be incited to place it in the CD drive . After concluding the above steps, please attempt to admission the Microsoft Update site once more to observe whether you have productively installed the update.
Thanks and regards.
When you try to start MS Office 2003 or MS office 2007 program you will get this error message due to the following reasons.
Two users have installed MS Office in the same computer.
Both installations were completed to set the installation for the installing user accounts only. You have set it as AllUsers=”” .
When both users were prompted to remove files that were copied locally, at the end of the installation, both users have not removed those files.
One of the two users has removed MS Office.
To solve this problem start the set up program for Office and follow the following steps.
Insert the MS Office CD to the CD drive.
Let the setup to start automatically. If not locate the setup.exe and start it.
After the setup window appears cancel it, and respond to the prompts to exit MS Office setup.
Bresneff
It seems virus attacked your system.Please follow the below procedure:
-> If you don't have any antivirus download a latest copy of antivirus and install it in your system.
->After installing antivirus open its control panel and start scanning your whole computer.
->If virus found clean it from your system.
Then go to control panel->add/remove programs->uninstall the MS Office.Then perform the below instructions:
-> Insert a fresh copy of MS Office 2003 in your PC..
-> If the Setup program does not start automatically ,Go to DVD/CD drive, locate the Setup.exe file on the CD/DVD, and then double-click the file to start Setup.
-> After the Setup window appears, cancel Setup process and then respond positive to the prompts to exit Setup.
You may encounter this error on Microsoft Office 2003 or Microsoft Office 2007. When the error is triggered, you may receive something like this: “Error 25090. Office Setup encountered a problem with the Office Source Engine, system error: -2147023836. Please open SETUP.CHM and look for “Office Source Engine” for information on how to resolve this problem.” There are several reasons why this error happens.
One of the several reasons for triggering “error 25090” is if two people installed Microsoft Office on the same machine. Another reason for this error is if both installations were performed using the AllUsers=”” parameter to set the installation for the installing user account only.
Another reason for this error is when both people were prompted to remove files that were copied locally at the end of the installation but both people didn’t remove the files. To fix the problem, just insert your Microsoft Office 2003 setup CD on your optical drive then wait for setup to start automatically.
If setup didn’t start automatically, start Windows Explorer then right-click your optical drive or the Microsoft Office 2003 CD and select “Explore.” Locate “Setup.exe” on the CD and double-click it to start setup. After setup starts, click to cancel setup and then exit setup.
The reason for doing this is that setup fixes the error condition when it is first invoked that’s why you don’t have to complete the setup program.
