Error 255 on IBM CoZBATCH
I am using IBM CoZBATCH utility program and I am receiving error 255 while trying to transfer a CSV file to the network drive using FTP. How can this be resolved?
Hello Charlie Richardson,
You should check to ensure that a connection has been successfully established between the computer and the network drive for the files to be able to be transferred successfully. The problem may be as a result of the two devices not communicating with each other.
Also make sure that the folder that you are copying the files to on the network drive has been shared so as to receive document from other devices, because the problem may be as a result of the drive not being shared on the network so as to communicate with other devices on that network.
Hope this helps.
__
Regards
Lee Hung
Notifications
